Zildjian said:Hi all, im after a second battery for my 350D, what one should I be looking for? All this 'mAh' is confusing me...
No you can get 4x2100mAh with a charger at a certain high street photography store for under a tenner I think.Zildjian said:Thanks, I have found 2 X 900mAh batteries for £18, is this good?
Colin_da_Killer said:No you can get 4x2100mAh with a charger at ******* for under a tenner I think.
Joe T said:1. The OP wants batteries for a 350D which uses a proprietry battery.
2. The shop you mentioned is a competitor, please edit it out.
Thanks
To the OP, you need either an original canon battery or a "canon compatible" of the type you need. 3rd party batteries are generally just as good as manufacturer ones. Have a look at the various auctions.![]()
Ive seen a couple on the bay that are higher. I wouldnt worry about it.Raymond Lin said:That looks the right one except it exceeds the Canon's own spec thou, dunno if its a good thing. Most Compatibles i've seen are have lower mah.
