Which CAD software is everyone using?
Caporegime
24 Oct 2012
Yer nan's knickers
This seems to be a question with about a billion different answers and the opinions are all over the place. Fusion360 seems to be the most popular, but it also seems to be the one that's gradually restricting more and more functionality beind a paywall as it ages.
FreeCAD also seems quite popular but has a much steeper learning curve.
Ideally I'd like to print my own design in the next week or two, but no idea which software to try.
What's the consensus on here?
Cheers :)
I had used Sketchup for a few smaller 3D designs some time ago, mostly for mocking up woodworking projects. Then I wanted to design my workshop so that I could alter things and not have the model explode. Fusion 360 was what I learned.
Watched some videos, redesigned 2 of the woodworking projects that I had previously done in sketchup so that they were parametric, more to get used to the way of working, and then went from there. My workshop file ended up being quite complex with a vast array of formulae to calculate and number of different things so that I could, on a whim, decide to make my workshop have a 31 degree pitch roof instead of 30, and also make it 1 brick wider and 13mm taller and the whole model would recalculate. This included things like the birds mouths on the rafters, studs and other timbers being added or removed, noggins, headers, internal sheet goods for the walls all being resized to fit perfectly, even if odd sizes, etc etc. I was very happy with what I had learned and how well it turned out.
Start simple, work out how to make a cube with a cylinder sticking out the top and a couple of bevelled edges. Don't make it massive, you want to see the whole process through from design to slicing to printing. You're going to need to think about how 3D printers work best and where there issues lie in how you design or print things. For example, the face that is touching the print bed will print fine with 45 degree bevels on all sides. It won't look nearly as good if you try and print with a roundover because the initial layers have too large of an overhang with a standard layer height. Lowering it can help, but not always solve the issue.
Think about line widths and layer heights too when designing. Lets say you want to make a small pot to hold some screws. Flat base, 4 walls. Maybe think about making the walls (assuming you're using a 0.4mm nozzle) a multiple of 0.4 in width. Height is less of an issue, but still should be considered where possible.
If you hate the camera controls they can be changed, but only to some defaults to mimic other applications. I prefer the tinkercad option, not that I have ever used tinkercad, but it allows moving the view around without using the keyboard.
With all 3D modelling there is nearly always 3 or 4 ways of achieving the same result. As you learn you'll find which ones are best for certain situations.
I have been trying around with OpenSCAD where I need to try a few different things like wanting a hex grill as part of a bigger model.
Fusion 360 here too, the only annoyance is the constant nag to upgrade from the hobbyist version and the max editable documents limit, but nothing functionality wise.
I only use the free version and the only time I've found it limiting for the things I do is I think in drawings you can only have 1 sheet which is a bit of a pain sometimes for woodworking projects and the 10-item editable limit, but it takes seconds to mark one as read only and realistically I rarely go back to a design once I've done the thing I needed anyway so at most I might have 3 active that I'm actually working on.
Been in CAD since the 90's....lots has changed since then, so much easier to use most packages now.
Stared with Pro-Engineer but now almost solely use Solidworks, this is my job so if I need something drawn to be printed I normally knock it out in a lunchtime.
I use Draft It paid for, nice and easy not really great for engineering but ok for construction
