gl hf9800gt is on par with the 8800gt
Avoid it like the plague.Is the 256mb version of the 8800 GT worth getting?
Depends on the resolution, if you only play at 1280x1024 or 1440x900 or below it will be ok for most games, but modern games like crysis and far cry 2 will struggle with only 256Mb of VGA RAM
£60 should get you a used 8800GT 512Mb, in fact you were offered one in your wanted thread for £60 so id take that.
Also for your £60 budget an 8800GTS 640Mb would be a fine card, one went recently in MM for £45![]()
I was offered one but someone else wrote in my thread and poached it!
