I currently use a Nvidia gts 8800 640mb, it has no problems with any games on max settings, ive read people have said it wont run crysis on max or mirrors edge or some other games, but thats just complete nonsense. I will soon be looking for a better card anyways with a budget of 250, what shall i get peeps, nvidia only i can't stand ati.
My setup if it helps to choose
Wolfdale e8400 3ghz intel core duo ( overclocked@ 4ghz ) https://www.overclockers.co.uk/showproduct.php?prodid=CP-192-IN
Asus P5Q motherboard https://www.overclockers.co.uk/showproduct.php?prodid=MB-277-AS
8gig dominator corsair (2lots) https://www.overclockers.co.uk/showproduct.php?prodid=MY-148-CS
Coolermaster Real Power 700 watt modulas psu https://www.overclockers.co.uk/showproduct.php?prodid=CA-148-CM
I run vista 64bit, i game on a viewsonic 22inch widescreen monitor 1920 x 1080 using a hdmi cable. As i say the 8800 gts 640mb has no problems and plays all games on max smoothly, i will be getting a new card in a month or so. Thanks all for your advice.
Also temp in my case , cpu and gpu is fine.
