- 8 Aug 2005
currently using a gainward 8800GT and having some issues (its on its way out) with it so I was looking to replace it. However i am stuck with what card to choose, looking at either a 1Gb 4870 or a 260 card. Have used ATI and Nvidia and am not bothered which i have I just want the best bang for my pennies bearing in mind the rest of the pc spec (cannot afford to change anything else).
PC spec is
C2D 6850 @3.5ghz
4gb ram
3 x 500gb HDD
Abit IP35 Pro mobo
Tagan 530w PSU
P182 SE Case
Dual booting Windows Vista (32bit) and Windows 7 (64bit)
PC spec is
C2D 6850 @3.5ghz
4gb ram
3 x 500gb HDD
Abit IP35 Pro mobo
Tagan 530w PSU
P182 SE Case
