Which CPU is faster
18 Oct 2002
North
Phenom II x4 @ 3.1ghz or Athlon II x3 @ 3.5ghz
I have 2 AthlonII 425 x3 - one that unlocks too full phenom plus cashe and the other that does not - the other clocks a bit faster.
Which one is best to keep?
I would keep the one which is the Phenom II as the extra core and L3 cache would be better in most cases.
This comparison between a 2.6GHZ Phenom II X4 and a 3GHZ Athlon II X3 would give you an indication of the relative performance of each processor:
http://www.anandtech.com/bench/default.aspx?p=85&p2=119&c=1
Also could you post any performance benchmarks with the Athlon II in this thread if possible please:
http://forums.overclockers.co.uk/showthread.php?t=18106677
If you could also do the same with the Phenom II in this thread it would be great:
http://forums.overclockers.co.uk/showthread.php?t=18108943
