Which CPU road should I go down?
7 Dec 2009
Hello,
I'm looking to build a PC, which I haven't done for a long time now. I'm not sure what CPU I should be looking at. I want to stick with Intel but don't know the differences between Core 2 Quad and i5. I'm looking to spend around £160'ish. The PC will be used for gaming, low level photo editing, web design and music/video playback. At this stage I'm not looking to overclock.
Any advice you guys can give will be appreciated. Can you suggest any good websites I can use for reference?
Thanks in advance.
PJ
I5 750 and OC to 4ghz
If your going to add 1-4 Cards in SLI or crossfire go for X58 mainboard and I7 920-930.
I hope you mean £160 for the CPU alone otherwise you won't get anything for that money even a E5300 + ram + cooler + mb is £240?
If building fron scratch, definitely i5 750 over Core2Quad. Cost less, faster and newer tech.
If going down the i5 750 road and think you might go xfire/SLI in the future, make sure the motherboard you getting would provide 8x/8x lane when xfire/SLI, as most sub-£120 1156 motherboard their 2nd PCI-E x16 slot drop down to 4x lane when xfire/SLI, meaning that it 'support' xfire/SLI on paper, but in reality it doesn't.
Tbh with your budget you may be best off looking at a Phenom II cpu because they come with a higher stock frequency than the i5's which is good since you mentioned that you werent looking to overclock. But if you insist on intel the i5 is a good choice.
Phenom II cheaper, cheaper motherboards usually too, the 955 is 3.2GHz and 965 is 3.4GHz but don't have the intel features.. might be worth thinking about if not OC'ing
But best in the price bracket is the i5 750.. it's pretty much an updated Core 2 Quad, and has turbo mode.. hence the 'update', the i5 is on offer at the moment . Turbo mode means it will reach 3.2GHz without you changing any settings or overclocking yourself, the other i5's are dual core
Both are similar but Intel will OC better
I love AMD but have an i7 XD
Intel is getting through sockets stupidly fast lately. With all their money you'd think they could design one that didnt need to be updated 2 years later.
You do realise that i5 750 stock speed at 2.66GHz is actually FASTER than Phenom II 965BE at stock speed 3.4GHz and even Q6600 oc at 3.7GHz right? Guess not.
Also, the i5 750 can overclock by around 1.5GHz, whereas Phenom II 965BE only overclock by around 600MHz.
As for 6 cores AMD CPU, it would need to be significantly faster than the current Phenom II to be consider meaningful upgrade. Having 2 extra cores over Quad would benefit multi-thread applications and video encoding etc, but it won't boost gaming performance unless game developers write the games to support 5th and 6th cores, which I don't see will be happening in the near future.
How many people actually upgrade the cpu after the first build?
I keep mine until I need to, by then the CPU socket changed 2-3 times, AMD and Intel, my last one didn't support DDR3, or have PCI-E, and just had SATA, DDR3 will last probably another year, I hope PCI-E stays and SATA is good just because it's backwards compatible. If you upgrade the CPU and keep the motherboard, you are almost always going to be behind the latest CPU sockets anyways..
i have the intel i5 750 together with Gigabyte P55 US3L.
What a monster of a combination this has been.
Really cheap and very overclockable if you need it.
Just remember to buy
the 1600mhz ram, so that you have the best option when overclocking.
Runs really fast and smooth with win7 64 bit
I would probably wait until the Phenom II X6 1055T comes out in the next week or two to see how it performs. The Core i5 750 has started to creep up in cost over the last few months and having another CPU in a similar price range should hopefully lead to a reduction in price.
That's true but even then the i5 will be better for gaming as I don't think any will be able to use all 6 threads, but 6 cores will be nice and tempting for many
The i5 is good for gaming when overclocked but since the op has stated he does not wish to overclock the high stock frequency of the phenom II 965BE and the upgrade path of the am3 socket seems better suited to his uses.
Numbers don't matter, the Intel has better architecture, A faster dual core will run faster than a slower quad core in terms of FPS, also in terms of FPS the i5 750 is just behind the i7 speeds, comparing the Intel and the AMD are really comparing apples and oranges.. you won't notice a difference in either really.
Intel supports higher ram speeds and has turbo mode
AMD is cheaper and higher stock speeds
If you went for i7 then you'd be able to use the x6 i7's aswell... once the price drops..
