which CPU water block ?
15 Feb 2009
Hartlepool
I've just ordered a intel 3570k coming from AMD so I need a new block
Budget £0-£50 may go higher if I will see a noticeable improvement
Alphacool NexXxoS XP³ Light - Acetal Edition - Intel/AMD £40
Watercool Heatkiller Rev 3 CPU Waterblock for Intel 1155/1156 Copper or black£48
Phobya UC-1 LT Intel CPU Water block Black Edition: Copper Acetal £38
Im swaying towards the ACool purely on style and knowing they make a+ radiators the bonus being it can be used for any cpu if I ever changed it, but I can't find any reviews that would show which is actually better at cooling ?
tbh I don't like the look of it, looks really cheap with the clear LED border and mount style but if its a lot better than the rest I could be talked into it
Personally I use the raystorm and it performs brilliantly. If you don't like the styling though then I would go with the alphacool. I am using one of the nexxxos radiators and it is a quality bit of kit. If the CPU block is built to the same standards then you should have no worries :D
Ok I am set on the Acool block now = D
All i need to sort now is block fittings a few places say 10-13mm compression fittings wont fit side by side so I think i need one vertical and one 45/90 degree compression to solve that, Then I need to find some reducers to go from 1/2" ID tube down to
