Thank you, still yet to decide on the sub, but appreciatedDefo hit me up if you see any around Brum plz!
Yes, I have 3x Monolith THX 15s V2s in Birmingham. You will NOT find better bass output, low THD and infrasonic bass for the money. They're absolutely phenomenal.
You'd have to pay close to £7.5k with Arendal or other competitor brands for similar performance. I'm letting them go for a lot lower than that of course, although the caveat is I'd prefer for someone to take all 3 (although I have a buyer for 2 of them if only a single is needed).
Reason I'm selling is to upgrade to Perlisten D215S. If you're keen, let me know and I'll list them.
Also have some speakers for sale too which I could make a nice deal on (Arendal 1723 8'' Woofer Monitors & Heights)
Guy on here is selling some monoprice subs birmingham. They're huge
They're a bit big but on their side, they're fine. There is also simple physics. For big, deep sound with extension and accuracy, you need a big box. There is no way around it. Either make it deep, or make it tall. Tall subs are normally an issue for projector screens.
If you want bass which call fill a moderately sized room, shake objects and provide in-room pressurisation - you need big subs. If you're aim is not to listen at reference and have a smooth FR from 12hz to 100hz - then sure.. can try to compromise.
I've owned BK subs in the past when I first started this hobby. Arendal, Monoprice and essentially most subs with Dan Roemer's design input seem to put them to dust.
