- 10 Jun 2010
- Scotland
Cheers.
There is an arrow on the top pointing in the direction of airflow. You can put them either way around so you have it as an intake or exhaust.
also not sure but the MX4 might need time to cure
according to the product description there is no curing time required for MX4. But the original coolermaster fan provides a greater airflow 69.69 CFM compared to the 57.53 CFM of the apache black
What makes the apache so expensive and wonderful then?
Noise, static pressure, and the air flow is decent anyway.
whatever you say.
