Which drive is which ??
23 Dec 2002
Shiny Shanghai
Hello !!
I have 4 drives C,D,E and F
But only 2 actual physical hard drives in my PC.
Is there a super clever way of finding out how I split them originally as I can't remember :confused:
Quick and dirty way is simply to remove one hard drive then see what appears in Windows, if Windows doesn't appear try again with the other one.
Alternatively try going into Control Panel - Administrative Tools - Computer Management - Disk Management and seeing how the partitions appear in there. I can't actually check myself as none of my drives are partitioned I'm afraid. :)
Disk Management will tell you or if you know the size of both drives then doing the properties of each drive letter and adding up might give you a clue.
