Which EK multi GPU bridge.
10 Nov 2009
Doncaster
Some may have seen my project thread some may not... If you have seen it, you will prob get a better idea.
I'm using a Asus Rampage V Extreme Motherboard, and 2x Evga 980ti Hydro Coppers..
Middle to Middle of the PCI-E slots measure in a 1.6 inch.
I am required to use slots 1 and 3 to get 16x 16x out of my gpu's...
As much as people do it, i'm not a massive fan of using fittings and pipe between the GPU's as a method of connection for cooling..
I'm rather fond of the EK Plexi Bridges..
Enter the problem..
For use with motherboards with PCIe x16 slots 60.9mm (2.4") apart!
Unless im being totally blind.. I've looked direct with EK and i cant seem to spot a block that will fit the gap..
Could someone clarify this please..
Thank you.
Enter the problem..
Thank you.
The EVGA HydroCopper blocks uses a special wider terminal per EVGA's request.
Because of that, you can't use our EK Terminal Bridges with them. You will have to go with fittings and tubing sorry.
