Hello all
Just looking for some advice, I'm looking for one or a couple of external hard drives to store some of my files as my previous (250GB) drive is now full...
I'm wondering if its worth just getting the one 1TB drive or would it be worth getting a second etc for backing up the other drive?
Can anyone recommend which to go for? (going by OcUK shop obv)...?
Thanks in advance
Budget is anything from £0 to about £60 i guess, may be able to push slightely more
EDIT: Or...can anyone recommend brand names? As OcUK's list isnt huge, and other stores have more options for example
Thanks in advance
