That's a pretty nice clock on such a low priced chip! What cooling are you running on it?
Are the supplied coolers enough to take it to 3Ghz? Case has decent air movement.
3Ghz I can do on just one increment above stock voltage!I'm currently tweaking my E2180 overclock. 3.4Ghz prime stable now. Running pretty toasty though, but incredible bang for buck. I recommend it.![]()
What temps do you get under load?
