Hi guys,
Just ordered some new toys (Q6600+Asus P5E) and have been looking for the best cooling solution. I've got an old Coolermaster Praetorian which is a bit tighter than a normal full-size chassis. Reading the forums everyones recommending either the Thermalright Ultra-120, Tuniq Tower 120 or the Noctua NH-U12P, but all of these are upwards of 150mm tall and I'm worried that it will stop me closing my case! I've read some good reviews on the Thermalright Ultima-90i and because its 139mm, it 'should' fit
What's not clear though is whether or not it comes with a fan. I don't think it does so if I buy one separately, are the fixings included with the hs to attach it?
Cheers.
Matt.
Cheers.
Matt.
