- 18 Aug 2019
So - my build came with a pair of Coolmaster Silencio FP 120 PMW fans (one intake and one exhaust).
I have bought 2 x Be Quiet Cool Wings 3 120mm PWM fans to add.
Im going to run 2 intake and 2 exhaust (rear and top-rear), but each pair from a single header (one header to each pair).
I THINK I have things right, from reading the specs but want to double check. The front fans have the air filter, and the case front )(*and sound dampening) where as the exhausts have no covers, no filter and no dampening. From this I believe I want the quietest fans on the back (from a noise perspective) while the front ones should have the highest airflow and pressure.
From specs then - I want the Silent wings at the front, and the Silencios at the back - specs are:
Coolwings: Speed up to 1450 rpm, Airflow (max) 50.5, Air Pressure (max) 1.79, Noise (max) 16.dba
Silencio: Speed up to 1400 rpm, Airflow (max) 44, Air Pressure (Max) 1.69, Noise (max) 14 dba
From those the Silent wings have more air flow and pressure (ideal for the front) while the Silencios are the quieter fan (ideal for the back).
This is my first time sorting this type of stuff and and just wanted to double check myself.
Thanks
Thanks
