Which GPU for my build
28 Jun 2012
Hello
Need help buying a GPU, i have a DELL S2719DGF freesync, so looking at 120fps at 1440p. The rest of my specs are i7 9700k @ 5Ghz, Z390 Gaming Mobo and 16gb of RAM.
I would ideally like to spend around £400ish
Are you suggesting the Vega 64 because i have free sync? im sure it doesnt matter due to nvidia having new drivers or something or is that the best card? how would i compare to a 1080ti?
If you don’t mind a second hand card, a 1080ti will smash your requirements with ease, my nephew has one which was a replacement for a Vega 64, imo (and his!) the 1080ti is the better card.
(I’ve got a 1080ti which I run @4K)
I’d be looking for a used one with transferable warranty,ideally.
If you want new which is understandable, the Vega is still a sound buy though.
And I wouldn’t touch the 20xx series with a barge pole. :p
I believe it's currently the best value for money, and a great card for 1440p. But if you want to buy used, then it sounds like you already have something in mind.
Cant give a link to competitors. Ive given you enough info to find it though ;)
Interesting, whys that?
If you are buying AMD Gigabyte and Asus coolers don't do as good a job as Sapphire and Powercolor.
In the £300-400 bracket the Vega 64 is the best card new. If you can bag a 1080ti with warrenty for a similar price then that's money well spent.
1080ti or 2080 with a 9700k. You've bought a brilliant CPU, should pair it with a brilliant GPU. at 1440p tho, u could get away with AMD. I'd go for a radeon VII.
If £400 is max then Vega 64 like others have said, but I would spend the extra and get a 2080 when the Super cards come out it might drop the current 2080's a little bit. You can get a 2080 for £650 at the mo and it will be a beast at 1440p 144hz
If 400 is max wait for Navi 5700XT
As much as I think it's poor price/performance the 64 prices here aren't that great unless you want a blower
£400 isnt max I could stretch a couple of hundred pounds , but was thinking that when PS5 etc come out that ray tracing will become more of a thing so thats what puts me off the 1080ti, maybe i will just wait and see what these super cards bring to the table, hopefully maybe get a 2080 cheaper on an auction site
I would be impressed if next gen consoles can actually push 60 FPS @ 1080p.
Chances are they will, but with Ray Tracing? Not a chance considering the RTX 2060 cannot do it
Cheapest I can find is £280
The Sapphire Nitro Vega 64 is £340 from a well known site from Germany
Its 280 euros. There are now multiple sites offering them, wonder if they are clearing stock or they know there are fundamental issues with them?
I would wait for the RX5700 to launch next week,and see how the prices of the RTX260 Super compare to it too. If you can find a secondhand GTX1080TI it would be faster than both of them.
Clearing stock. It's now an EOL product, and they're likely making room for the new Navi cards.
