Hi all,
I am looking to upgrade my graphics card for a gaming system and have up to £180 to spend,
I upgraded pretty much the whole system recently but the GPU (MSI GTX 660 twin frozr) i bought was faulty and had to be rma'd.
I wouldn't mind getting another GTX 660 but i really am not sure if it is the best bang for my buck, i was looking at the HD7850 and that seems pretty good also
basically if you were me and you had the choice of any GPU in that range which is
a) the best card
b) the best performance per £
my current system is
i5 3570k
ATI HD 4870
Gigabyte Z77 D3H
8gb corsair vengeance
ZT 550w ocz
Thanks loads! in advance for any advice i really cant decide, i spend so much time sifting through the different options i need help.
a) the best card
i5 3570k
ATI HD 4870
Gigabyte Z77 D3H
ZT 550w ocz
