- 9 May 2009
Hi all I hope you can help.
I am going to build a media centre pc and I was wanting to be able to play every single video format out there including 1080p mkv files and blu-ray.
The other thing is I want it to be silent as possable so I was looking a passive GFX to buy to play every single video format with ease.
I don't want a chip that can just manage it but the best you can get that will run it without a sweat.
I want to be able to get dobly digital HD and Master DTS Hd to from teh hdmi as this is the only way you can get these sounds to my amp which can decode the hi-def sounds.
is it better to get a sound card that does this ?
is there any problems with blu-ray and hi df playback with the ati or nvidia card at all which is best to use and i am looking for a card with the video accelerator.
can media pcs produce top rate pictures l;ike a high end denon 2500 blu-ray player ?
also what motherboard should I be looking at ?
Thanks for any help
Thanks for any help
