Coil Whine reduction technology: We specify the capacitors to be enclosed in plastic containers and then stuck with glue to PCB as it helps reduce/eliminate coil whine
Thanks, they are significantly more than some, every penny counts unfortunately
Looks like its just luck of the draw... and sometimes PSU
Mostly luck...you can always return an item within 14 days if you are unhappy without worrying about RMA![]()
Yeh, and be eligible for an up to 25% fee for the privilege.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-039-IN&groupid=701&catid=1914&subcat=1010
Any problems reported with this one?
