Pretty sure this picture explains things nicely, Always show it to friends when they ask this question.
yeah....except that isnt true.it either works perfectly or not at all.
You've been completely conned, a website did an analysis recently on just this very topic, using hash checks of images sent over various HDMI cables, from super cheaper ones, to very expensive, and they all produced the same hash value. So these "wonder cables" weren't making the picture better at all.
Whilst I don't doubt a poorly built cable will struggle over such distances, I don't understand how the differences would manifest themselves in colour saturation/sharpness - surely errors will look like artefacts on the screen, which is going to be the result of a faulty lead, in which case you could just take it back and get another!
Also, £100 for the cheaper cable? I know it's 16m but i wouldn't call £6.25/m particularly cheap for a cable!
If HDMI cables are subject to external sources of interference then why when Digital Foundry transmitted the same (still captured) image over 4 separate cables, where the image checksums (hashed) had been calculated before transmission and after transmission they were identical, with no error correction then, they could not have been susceptible to external interference for even one pixel changing would have resulted in a different checksum (hash) from the one transmitted.
These were also randomly selected hashes from the video stream, so there was no change over time. Even the tiniest change in the signal, that was not perceptible to the human eye would have resulted in a different hash
Mushii
Note that 'very long' is undefined...On the face of it, the conclusion is that you can run any HDMI cable - no matter how cheap - and get identical results. However, very poor quality cabling can present image problems in certain circumstances, and the accepted wisdom that with digital you either get an image or you don't isn't exactly true. A low quality, very long HDMI cable could work fine at 720p for example, but could introduce digital artifacts at 1080p.
The point being that generalizing that all HDMI cables are the same and work or do not work is incorrect as stated by an article you used as justification of your viewpoint (but for some reason didn't link to). All cables are the same (more or less as not every single cable available was tested) up to a length of 4 meters. People do sometimes have longer requirements and if they listened to the 'the're all the same no matter the cost' crowd then they can potentially end up with a crap cable which gives issues and not understand why. I almost went that route and almost ended up with a cable that gave a less than perfect picture. After you have chased the cable in the wall, you would tend to get pretty upset if you started seeing issues with the cable and had to remove it and try and get a replacement.Independent testing suggests that just about any HDMI cable works fine at lengths of up to four metres
Be glad you asked and have saved being ripped off. I still think that gold plated optical cables are the best thing I have ever seen being touted.
http://www.qed.co.uk/102/gb/product/performance/optical.htm
.Whilst I don't doubt a poorly built cable will struggle over such distances, I don't understand how the differences would manifest themselves in colour saturation/sharpness - surely errors will look like artefacts on the screen, which is going to be the result of a faulty lead, in which case you could just take it back and get another!
) so I may be able to talk the guy in to letting me take my Canon 5D in with tripod and remote release to see if I can capture the differences.
.Maybe one cable wasn't 1.3 spec and so DeepColour could only be displayed on some of the cables?
Far more likely to cause a colouration difference than interference or degradation. Signal degradation in HDMI will almost certainly show itself up as sparkles or corruption, not muted colours and slightly softer edges.
I will be buying a new amp soon and need some speaker stands and speaker wire (cheap wire for rears and sides) so I may be able to talk the guy in to letting me take my Canon 5D in with tripod and remote release to see if I can capture the differences.
RB
OK, so taking photos how do we know that,
- Your 5D is as good as it gets in terms of accuracy.
- The lens isn't skewing results.
- You are taking the best possible picture in the shop with the camera setup properly with the picture taken as best it can be.
- The lighting in the shop won't affect the picture.
And finally, how well is your montior calibrated for viewing pictures and how can we all see the same thing when everyone has a different system, montior and settings
Just watch the HDMI event videos in the avforums video section for some in depth facts on HDMI cables from the bods that test them.
absolutely,
Best analogy I could think up of is a dvd that you rip to a hard drive suffers a bit of corruption. If the corruption is small then how does it show up..... as artifacts on the screen. It is only if the corruption is pretty bad that you loose the picture / sound completely.
RB
you are correct and i have seen it with my own eyes. i had a cable that gave me massive screen corruption at 1080p with a sony bluray player, and failed to produce a picture completely with an ati graphics card. This cable, funnily enough, worked perfectly fine at 720p. it's the only cable ive ever seen do it but jesus when it artifacts, it's easy to spot. Think old analogue-snow, except in wondrous technicolor lol.
Amazon Basics at £5 each if you want a nice looking one![]()
http://whathifi.com/Review/Amazon-Basics-HDMI/
If you're only willing to spend £5 on a cable at least get a half decent one from "THATCABLE", if you're gonna spend a lot on a/v equipment at least do it some justice with decent interconnects. I've never spent less than £25 on a HDMI, get a QED profile.
