Which headphone stand for your HD650s?
26 Nov 2012
So according to this video:
He doesn't recommend stands with small / thin contact points as "the headphone may bend down and sag or leave an indentation", which I guess makes sense.
He reckons the bent wood Omega style stand "compresses the ear pads, and spreads out the head band too much"
He then suggests his wider stand is amazing but "don't store them on here for longer periods of time because over time it'll still compress the underside of the headphone band, especially for heavier headphones".
So, what have people found with their HD650s and stands causing near Armageddon - at least according to this guy ;) Are they heavy cans? Do you really care that much? What's your favourite stand?
I'm currently thinking... 'Avantree Universal Solid Steel Headphone Stand Hanger with Cable Holder'
Asda mug tree - the narrow support fits nicely in the groove in the centre of the headband - a perfect fit :)
It does help, it makes putting them back in the box an option! No compression in the box of course, until you put it down on the floor and stand on it :D
I have been considering moving upmarket from my aluminium Asda model to a nice wooden one, as they have a thicker support :)
I mostly just throw them on the floor but occasionally I sling em on this ultra fancy fold out hook wot I bought from ikea.
i use a GVDV Aluminum Headphone Hook just looked at my akg 550s it has left a 2 small faint lines / indentions on the underside of the headband, not used them for a few weeks though i guess the guy in the video may have a point if you have super heavy headphones and your storing them on a hook style stand with a none curved styling for a long time. its not altered the fit on mine though still snug.
Mine go back in the box.
Sorry that doesnt help much :p
The box IS the best storage place for them.
A) The box is beautiful and padded inside
B) The box is secure and tough
C) The 650s are things of beauty and high value, so should be taken out of "storage" like it's a special event every time
No ifs or buts!
Guys...same here ...I've got the Siberia 800s which I use for gaming and I keep them in their box ....also got X2s....they have only been out their box once. And finally got Dt770s..they don't go in their box but in the bag that was supplied....I keep all my gear back away nice and neat....must be. An ocd thing...lol
The konig Meyer ones are the best imo. No pressure on the cups and very wide band support. Is resin with matte rubber coating. You can get them that attach to the table or to poles. I've got mine attached to my monitor arm
