- 24 Oct 2005
- Hull
Hi All after a little advice at the moment im running one a X2 4400+ with the amd heat sink and my temps are very high imo at 25 idle 44C load
what heat sink would be better looking at a Thermalright XP-90 is this a good choice or is there anything better out there but dont want a loud noise either from a big fans on the heat sink lol i know some of the fans i tried before can be loud
lookforward to your ideas guys cheers
see my sig for specs cheers
Getting good temps even with the 120mm sitting at 800rpm
