Which i5
27 Mar 2016
Bristolian living in Swindon
Hi all
New build, Which processor would you all choose, Im thinking i5-K model for overclocking... But not sure which one to choose, Ive seen i5-2500k about at second hand prices but not sure what they perform like...
Id like something that will future proof me for a fair bit
Thanks
The 2500k performs well but you will need to find a micro atx motherboard which can only be found second hand and usually overpriced.
Personally i would go with something new and with warranty unless your on a real tight budget.
Ive found a few Micro ATX motherboards around... If you was to choose a CPU which would you go for?
6600k would be my choice new but only if your going to overclock.
I have read a few of your posts and i know what a dificult choice it is, now you have your case you should state a budget and see what you can get.
Heres a starting point you will also need a cooler but reading some of your other threads you going for a all in one watercooler.
Theres also cashback on cpu and motherboard, check to see if oem cpu qualifies or retail.
https://www.overclockers.co.uk/lp/intel-cashback.html?__ckdesktop=1
Mite be tempted to get the Z170MX-Gaming 5 with cashback makes it a good choice.
My basket at Overclockers UK:
Total: £386.43
(includes shipping: £10.50)
Your a top man, cheers for your help, the 6600k was what a lot of people have been talkin about... Yeah your right I'll be goin for all in one watercooler for now :D
Sorry to be a pain, is it worth getting the extra dosh and going for a i7 6700k or i5 4690k as I've been selling bits and bobs around the house lately so got that bit more to spend
For gaming get the I-5, would be no real diffrence in performance geting the I-7 so put your money somewhere else in the system.
e.g , SSD , better motherboard or gpu, etc.
I've seen a few i5 4690k CPU's for sale so if I get that then get myself a nice Micro ATX motherboard with the money I've got left :)
A 3570K is socket LGA1155 and needs a Z77 board for OCing. That said, it's still a good chip at stock and OC'd.
A 4690K is LGA1150. The 4690K will work on a Z87 (may need a BIOS update) or a Z97 board.
Z77 boards are getting inceasingly rare, particularly m-ATX versions, as you can only get them second-hand.
Alternatively, if you can afford to, you could just get a brand new Z170 board and a 6600K.
I shall have to have a look around then for a Z77 or Z97 board, may find something used.. Are there any new MATX boards that will accompany it for my build
I would go with the Z97 route, as the boards are likely to be more available, used or new. In fact, you might be able to get hold of a new Z97 board even though they're end-of-line.
The Asus Gryphon is a high-end board and is somewhat expensive at £140:
https://www.overclockers.co.uk/asus...150-ddr3-micro-atx-motherboard-mb-621-as.html
This is out of stock at OCUK, but I know from googling that competitors have it:
https://www.overclockers.co.uk/asus...150-ddr3-micro-atx-motherboard-mb-616-as.html
I've got the Z97M-Plus in my m-ATX build and I'm very happy with it.
Thanks for your help mate, I do like the look of the Gryphon MOBO, I don't mind spending that little extra cash on it won't break the bank :D
