Hi, I am wanting to buy a cable to connect my PC to my TV so I can watch DVDs and other video played on my PC to save me buying a separate DVD player.
My graphics card is a GeForce 7900GTO and has two DVI connectors as outputs, one of which goes to my LCD monitor.
I have a 26" LCD TV and have a range of connectors at the back. These are:
VGA
RF
Video
SVideo
YPbPr
2 x Scart
2 x HDMI
Audio inputs: Audio R/L. PC Audio, YPbPr Audio R/L
As I said, 26" ratio 16:9, definition 1366(RGB)x768.
VGA support up to 1024*768 60Hz
YPbPr support up to 720p, 1080i
Double HDMI support up to 720p, 1080i.
Which type of connectors should I be looking to use here? I would like to be able to use it for high definition video, so YPbPr or double HDMI sounds like the best but I would really appreciate some advice. Also, do I need a separate sound cable from my PC to the TV or will sound also be carried in the picture cable?
I will be needing about 4 or 5 meters of cable if that makes any difference.
Thank you very much for any help.
VGA
RF
Video
SVideo
YPbPr
2 x Scart
2 x HDMI
