Which is best atm
10 Nov 2006
Lincolnshire
I currently have a Samsung Spinpoint 1TB and looking to jump on the SSD band wagon, I need 128GB minium for O/S and 2 games max, the Samsung will be used as storage and other games.
Which is the fastest best option?
The Crucial M4 has always had a good reputation and I can personally vouch for the Samsung 830.
No problems in the relatively short time I've had it (256GB version).
Got both the M4 and Sandisk Extreme and very happy (Sandisk for a short time thus far though).
Samsung supposed to be very good too.
ocuk give you 15 quid discount for taking norton ghost off their hands. and it also comes with a 3.5 to 2.5 inch mounting bracket (not that it is really needed anyway)
otherwise, the drive itself is exactly the same. lol.
The cheaper one if the better package as it comes with a 2.5"-3.5" tray if you need it.
The drives are identical so just get the cheaper one.
