Which is better?
21 Jun 2004
Berkshire
Out of these two, which will provide the best performance/responsiveness within Windows.
1x WD 300GB Velociraptor
OR
2x WD 6400AAKS RAID-0
Im thinking the raptor due to access times?
Chris
Personally id go for the raptor as its a shi* hot drive and 1 drive uses less power than 2, meaning it will draw less power from your PSU, just my 2 cents :)
I have two WD 6400aaks in a raid 0 set up.
1 160GB volume for the windows and apps
1 1032GB volume for storage
ive just run HD tune and this is the result, not bad seeing as its been up and running for 5 months. I would have expected it to slow down more than it has with the usage i give it..:D
currant
when first setup
