- 3 Nov 2004
- UK
Stock fan yes.harris1986 said:fornowagain how's the tuniq performing for you? do you just have the stock fan in it?
Would it be fair to say the Arctic 64 is best in the performance/price and performance/sound stakes?Raikiri said:Edit: @ Stelly. The arctic 64 pro isnt the best, the best value yes but not the best performance.
squiffy said:I would like a few comments also, could pick up three of these, pretty cheap. One for stacker 810, another for SS TJ08, Qpack cube.
harris1986 said:agreed with raikiri Tuniq Tower > Sythe Ninja > TT Big Typhoon > Freezer 64 Pro
I have had the freezer 64 pro got very good temps it's the best value for money, but upgraded to a TT Big Typhoon which offered a lot better cooling see sig for temps! Am thinking of getting that Tuniq Tower
jmke said:"the best" without thinking about noise is the Tuniq Tower 120, it's 1kg large tower heatsink with small aluminum fins and a 120mm (25mm H) fan in the middle; if you run the fan at high speed the cooler will keep your CPU chilly as can be.
"the best" keeping noise in mind would be the Scythe Ninja, it has spread out fins which allow you to use a very low CFM 120mm fan and get excellent performance still.
for now; no others match the performance or performance/noise ratio than the 2 mentioned; the Zalman CNPS9500-Cu and Freezer 64 Pro and TT Big Tyhoon are FAR from bad, they only trail "the best" by a few degrees. And in the end I would go for the HSF which is easiest to get and cheapest all around.
this message contains conclusions based on an upcoming roundup of HSF heatsinks at www.madshrimps.be
fornowagain said:Keep an eye open for this guys posts or check the Madshrimps site for HSF reviews. IIRC he does their hardware reviews. Been reading their site for years. Worth a look.
http://www.madshrimps.be/?action=getarticle&articID=419
urm monster munch in that link u have linked to the page that shows the TT typhoon slightly quieter than the tuniq, the tuniq does actually offer better cooling as shown here in the same review : http://tomshardware.co.uk/2005/06/07/10_mammoth_cpu_coolers/page30.htmlMonstermunch said:This is wrong according to toms hardware.... They put the Big typhoon ahead of the tuniq tower. They also say that one of the two best in their test is the Thermaltake Sonic Tower, and that's without a fan fitted!
http://tomshardware.co.uk/2005/06/07/10_mammoth_cpu_coolers/page31.html
That's possible...........if your in a freezer.WatchTower said:20C full load on air is what I want.
