Which Karcher pressure washer?
24 Dec 2010
Anglesey
Hey im in need of a Karcher but I cant decide which to go for.
Mainly will be used for cars.
Not sure what pressure I need, but I don't think I need a very high one for cars, im not sure.
They can go up to hundereds of pounds but I don't get the difference.
I am willing to pay up to hundereds £250 but only willing to pay that much if the quality is considerably better than cheaper ones.
Thanks guys.
Only buy the ones made in Germany and not Italy.
All work the same just more hose and litres of water per hour and higher preasure the more you spend.
More litres per hour = faster cleaning /more cleaning power
Longer hose = less moving the machine around car/patio
Higher preasure = more cleaning power /faster cleaning.
The basic one will work/clean the same as top of the range just takes a little longer.
Tbh i dont think there's that much difference apart from pressure and a few other small benefits. We have the Karcher K2 (£92) and it cleans everything with ease. I dont think for car cleaning you need an extremely powerful one. Just get the K2 with car cleaning brush (£12), it gets great reviews on a well known retailer website.
My Nilfisk is almost older than my car (ownership years) and is still going strong whereas friends and family who have bought various Karchers have had them fail long before. Mine sits in the wooden shed year round and gets used weekly.
Nilfisk all the way. With Karcher, you're mostly paying for the name anyway until you hit the much higher end models.
Modern Karchers are rubbish compared to how they use to be.
Buy a Nilfisk.
Good customer service too:)
indeed, many of the professional valeters I know swear by nilfisk stuff for heavy use and reliability
Some iffy advice here. However, if you go for the K4 series, they are more reliable due to having ceramic internals.
If you want to spend £250, then consider this
Its a K6 from the Karcher outlet and its a pearl of a pressure washer if looked after correctly.
As with all pressure washers, you need to turn the power off and release the pressure when finished and not leave it plugged in and switched on for long periods. Over the winter, you need to totally drain it before putting it away unless you keep it indoors.
BTW, I am a semi professional detailer and I have a Karcher which is getting on for 15 years now. By all means buy a Nilfisk, but try and find a specialist who will service it...
Yes the k2 does look pretty good, just wondering, do I iust plug it into the outdoor tap and go? Because I thought you could put some sort of detergant inside it
Karcher were built to last 15 years ago, today they don't, know several people who have had one or more of the latest ones failed.
I usually have to book my Karcher washer in for repair every time I want to use it. Apparently if you don't use them very often then the valves are prone to sticking on them (told to me by Karcher dealer).
Apart from my commercial 745, I have a K2, which I bought in 2008 which does infrequent odd jobs when I dont have the 745 to hand. Make of that what you will.
Can you get something to reduce pressure on the Nilfisk? I'd like to use one for cleaning my bikes but don't want to be [high] pressure washing certain parts. By which I mean an additional attachment, or is the pressure controllable?
stand further away ;):D
