- 15 Feb 2009
- Bristol
I'm considering getting a mATX case to replace the Fractal Design R2, which while it's a brilliant case it's very big and very heavy.
Being a fresher at uni, having a big and heavy case is not ideal as I occasionally move the PC to and from my room and communal area, and i'll be moving in and out of different flats/houses during the next 4 years so hopefully moving to SFF would make things a lot easier. Especially as all the other peripherals take up so much room already!
A quick look over the cases and the one that stands out is the Sugo SG01, but i'm wondering if there's a better/cheaper case out there that fits my needs.
So here it goes:
1. Something that will fit a H50 or Freezer7Pro or similar size.
2. DVD drive bay fitting a normal sized drive (i.e. not slimline).
3. At least two 3.5" internal bays.
4. Fits something similar size to the 4870/5770.
5. Fits both GPU and sound card and has appropriate expansion slots.
5. Takes an ATX power suppy.
6. Not required but ideally front panel HD audio.
Thanks
So here it goes:
Thanks
That's impressive.
