Which memory do I need?
1 Jul 2007
Various
It's been so long since I built my PC that I've totally forgotten what RAM I need. I've got a socket 1156 MSI GD80 with a first generation core i5 CPU.
I'm still pretty happy with performance and don't feel the need to upgrade significantly, but would like to move from 4gb to 8gb memory. All I remember about my current memory is that it's dual channel GSkill Ripjaw, so what will I need to buy to upgrade it?
Ideally, I want something compatible with my current RAM so I can buy 2x4GB rather than two new 4GB sticks - I want to upgrade as cheaply as possible as there's not much point in dropping too much cash on such an old machine!
P55-GD80 - Supports Intel® i5 / i7 based processors in LGA1156 package. Intel® P55 Chipset, Supports four unbuffered DIMM of 1.5 Volt DDR3 1066/1333/1600*/1800*/2000*/2133* (OC) SDRAM, 16GB Max
you need to know current mem speeds and match accordingly to use current mem
YOUR BASKET
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLRED38G2133HC11ADC01) £65.99
1 x Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (AVD3U16001104G-2IR) - Red Light £59.99
Total : £134.68 (includes shipping : £7.25).
Cheers. Is there any way to work out current speeds without opening her up? Been so long since I've done this!
Cpu-z tells me the stepping is 9 9 9 24, but I can't find the speed...
You should look for the highlighted line as the picture above and multiply the figure you found by 2, there you will have the current memory speed.
