I was looking back through "my old documents.zip" ( <3 backups! ) when i came across some midi files i'd made. Anyways they aren't great but theres a certain amount of nostalgia for me
It got me in the mood to do some more composin' tho! but i don't know which to continue/complete!
So here are the links to the midi files and if you have time you can tell me which you prefer and therefore which i should try to complete.
They are all pretty short. 6 are less than 1 min 20 secs. just the last one is over 2 mins, but its slower paced so that explains it!
Midi 1 EDIT: Listen to midi 8 before you do this one because its just better :/
Midi 2 EDIT: Dont really like this one myself just included for completness.
Midi 3 EDIT: lol at the ending to this one, point and laugh at the violin (or it is with my soundbank) and imagine that bit *gone*
Midi 4 EDIT: I think i remember trying weird rhythms with this one. so may sound a little weird in palces :?
Midi 5
Midi 6 i realised is just a shorter version of 7 so no need for that to be here.
Midi 7
Midi 8 is the same tune as Midi 1 but i prefer it. Mainly pianos here
thx in advance!
kazatan
Midi 5
Midi 7
thx in advance!
kazatan
Although why you randomly drop from the tune to just the repetitive back beat im not sure
