I'm considering a new monitor for my rig and as you can tell by the title its main use will be for gaming, I'm currently pulled between 2 choices, these are....
Dell SP2309W or Samsung T220
My main concern is the resolution, I'm awear the dell boast's a massive 2048 x 1152 resolution but I'v heard playing games in this resolution has effects such as dropping in game FPS? There's also the fact some applications dont support this high resolution, what occurs if I try run them? Will it auto decrease the resol to the closest max setting for the app, if this occurs will the application be destorted in any way or would it appear as it would on lets say the samsung's 1680x1050 resol. I'v read up on both monitors and each of them gets 5/5 or high 90's % so the question is which one to go for?
Any feedback is apreciated, thanks in advance.
I'm assuming they were products claiming to be samsung originals but not?? What is the likelyhood of getting this CMO T220
