- 1 Feb 2009
Just about to press the button on a new system - the titan spinosaur i will order that with a radeon 6950 and a 60gb ssd drive. i may also add another 6950 for crossfire either immediately or if necessary.
i will be using a triple screen set-up for mainly racing (iracing plus others), flights sims (rise of flight, il2 : cliffs of dover) and some fps such as bfbc2.
the 2nd 6950 is not really necessary for my main use of iracing - it doesn't work well but i think i will see worthwhile gains for the other stuff. so .....
i now need to decide which monitor to buy - i will be using an Obutto gaming cockpit
Low input lag and good responsiveness are probably the most important consideration plus as thin a bezel as possible. Viewing angles shouldn't be too much of a problem as the side monitors will be angled towards me but
I am tempted by :-
Dell U2311H which as we know can be had for a good price at the moment
Samsung P2405H which nobody seems to have a bad word to say about it - is the bezel thin enough though ?
Benq XL2410T 120hz - many people seem to rate this on the racing forums for improved smoothness but the image quality itself seems to be average.
Getting a little greedy and looking at larger monitors like Hanns G HZ281HB - 27.5" and 1900x1200 which is a nicer format in triple screen although is more taxing or it's 25" sister which is a little unknown but may be a nice size for this setup.
One of the Ilyama 26" or 27" monitors - the 26" is a 1900x1200.
The latest batch of the racing cockpit should now take 3 screens up to 28" each.
Can't quite stretch to the Dell U2410 - too expensive for 3 of them.
As you can see I'm lost - I can't choose which sandwich to have for lunch let alone make a decision costing up to £1,000 for 3 monitors !
Thanks for any experience or guidance.
Cheers
I am tempted by :-
Cheers
