Man of Honour
- 23 Mar 2011
- West Side
Which X670E ?Probably the Asus X670E, but I'm not going to order until the CPU comes back into stock.
Which X670E ?
Looks that way; I think the only thing constraint is the 3rd PCIE slot and 5th M2 share lanes.I currently have the
ASRock AMD X870E Nova WiFi 7
in my basket
full bandwidth for all drives and 16 lanes for the GPU if I'm not mistaken?
Ah, that's unfortunate!Unfortunately it's not in stock the motherboard so going with X870e Hero from Asus
at the moment
and bought the 9800X3D from MM
I did mean my 9800 isn't due until the 30th! (Which is annoying as I have the motherboard and RAM sat waiting for it).
I did go for the MEG 870 Godlike, I have no real idea why other than I have the space for it, and I like the look of it.
Yeah, it is; BUT it's a pretty ridiculous build anyway and I should probably do a log when it all turns up (Shame I'll have to wait for a GPU upgrade but that should be a (fairly) easy swapout.Damn pricey MB - as long you get your moneys worth out of it, then all good.
Some of us are happy to use modern WiFi instead of LAN cablesIts funny how much harder it is to pick a motherboard these days compared to my last build on Z87 (an age ago i know) - i dont even know what to use USBC 40GB for or why i would need it. I'm also looking for a board for the same CPU - to build early next year. Having a hard time deciding -other than looks I cant really see a reason to get anything more than B650E. Whats with all boards having wifi now?!?
E-?And I got an email last night to say my CPU is on its way so I've ordered the Asus X670E.
Asus ProArt X670E-Creator WIFI (Socket AM5) DDR5 ATX MotherboardE-?
E-A , E-E , E-F
Quality board.Asus ProArt X670E-Creator WIFI (Socket AM5) DDR5 ATX Motherboard
https://mikrotik.com/product/crs305_1g_4s_in says who?Moar speed!
It's not just a question of NICs. There's the switches too and those aren't that cheap.
lol where did you order it from?It's just arrived. I'll be fitting it tomorrow. It was ice cold so leaving it until tomorrow will let it warm through and so prevent any condensation issues.
The box looked like it had been opened but the board looks fine. No seal broken but the cardboard tab was slightly adrift. I'm guessing that someone did open the box to check that the board was inside.
