which of these specs is best?
13 Jan 2006
Wigan
i was all set to buy this build:
but just before i did a friend said i should look at amd for low end.
so i came up with this:
useage is:
storage
downloading
web use
which is the better choice?
Neither are that important for the build but I do like the 6 sata ports.
It's also micro atx so I can have the case from the 2nd spec.
Thx :)
