Ok so just run the one lead from the psu, this lead splits into two, as explained,
On a side note, what's the better option running the extra fans off a molex or direct from the mb, these are only 3 pin fans so won't be getting a signal for speed?
I took out my old ssd and old gpu , then I put a brand new larger ssd in, installed Windows 10 and a few other programs back on, then after dog this I put the new gpu in this is where I hit a wall
Lol I know the thread is a bit over the place
Thought I should have started a fresh one,
I'm using a single 6 pin pci that splits into 2 leads with 6+2 On each end
