Which power supply?
17 Aug 2007
Maidenhead
Im building a new system, just need to find a decent power supply.
I have a max budget of £72 for the PSU (Inc VAT).
(I'm not intrested in hardware changes to my current spec)
Cosair - 550w or 650w.
Additional: you only need a DDR3 dual channel kit for an AM3 build - e.g. link.
EDIT: Also you may want to pre-order Win 7 for ~£60 and use the RC version until it's release - far cheaper and far superior to Vista.
Win7 has been pretty extensively tested due to the open beta - in fact it is an evolution of Vista so all views I have read thusfar (and experienced myself), suggest it is more stable.
"Out of Stock"
It was an example just to point out that you can get dual channel kits for the AM3 MB. Kingston/Corsair would be fine.
And the above.
for PSU my suggestion is
OCZ
y nt this ram
and yes i hav seen ppl using triple channel ram in AM3 mobo,and it wrks fine,
but is ther any perfomance differece???,bcuz we wil b using both rams in dual channel, is that triple channel ram better?
If you try running that tri channel kit on AM3 platform, it will only run in single channel mode.
You should find a dual channel kit instead like these.
This OCZ PSU should be just fine for that system
