Which Power Supply???
6 Mar 2009
The OCZ unit is a better unit as the total amps across the +12V rails equals 72amps. Where as the Corsair only has 40 amps across the +12V rails.
Ok Corsiar's out the window now lol
Im a fan of Antec so might just go for that. Didnt actually see that one when looking around.
Corsair HX Modular 650W, it's £10 more, 50W more and Modular. Personally I don't think you can go wrong.
That Corsair in your link is not modular. The Antec in the previous posts is modular though.
The HX you refer to is £99.
To be honest -if you can afford it - pay the extra £10 and get this PSU which is more powerful and better quality/efficiency.
Even if efficiency were exactly same I wouldn't touch that cheap China capacitor OCZ.
Just half week ago had Creative Gigaworks S750 say pop and play dead because of those damned cheap China caps...
And because of mainly using headphones I doubt speakers even had much more than 500 hours of usage behind!
Quick quiz: How much is 12V times 72A?
Damn! You're right!, Thanks for pointing that out, although it's still a good power supply. I'd say go for the OCZ then, looks of high quality and doesn't get bad reviews.
You should bother to look at reviews, you get efficiency tables etc, failure rates and what not if you look properly.
Hahaha, slightly higher wattage than anticipated? :D
