CPU is a Core 2 Duo 1.80Ghz
I've so far got installed the following software for cpu temp readings:
Asus Probe II
Intel Thermal Analysis Tool
On 100% load TAT is showing 52-55 degrees and Asus Probe about 48.
Which is most accurate? and do those temp readings look ok for 100% load using a Freezer 7 pro for cooling? (idle temp is around 40 using TAT and 35 asus probe)
Asus Probe II
