Which RAM for 3600mhz CL14 on Ryzen 3600?
11 Feb 2019
Hi, just putting together a list for a CPU/Mobo/RAM upgrade, and have settled on either the Ryzen 3600 or 3600X.
Which RAM is the best option for 16GB at tight timings to draw out the max performance from that combo?
VIPER STEEL 16GB (2X8GB) DDR4 PC4-35200C19 4400MHZ DUAL CHANNEL KIT (PVS416G440C9K)
TEAM GROUP EDITION 16GB (2X8GB) DDR4 PC4-28800C16 3600MHZ DUAL CHANNEL KIT
Are they essentially the same, just the Patriot Viper are higher binned so more likely to overclock better to get the tighter timings?
I couldn't really find much info about QVL and which Motherboard would pair well. Looking at MSI B450 Tomahawk MAX but open to whatever is going to get the best out of CPU/RAM, not sure if I need X570 for this or not. I won't be needing PCIe 4.0 for a couple years probably
People love the vipers. Go for it.
I personally have gone 8 pack (another 16GB winging its way to me now) as I like the looks of it.
Note: You'll be running either kit likely at 3600, whilst the kit might go higher...your infinity fabric may well not. I can run mine at 3800, but I choose XMP settings with tigher secondaries.
I'd go for want you like the look of and price.
