- 13 Mar 2006
Hello all, please can you give me some advice about what RAM to get to go with overclocking an EVGA classified and i5 750: I was thinking of either
Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel (PGV34G2000ELK) [PGV34G2000ELK] £115.98
or
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-16000 2000MHz Dual Channel + 3D Mark Vantage (PVV34G2000LLKB) [PVV34G2000LLKB] £121.99
or
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) [PVV34G1600LLKB] - 7-7-7-20 @1600mhz £82.76
or
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMD4GX3M2A1600C8) [CMD4GX3M2A1600C8] 8-8-8-24 @1600mhz £132.99
Am I missing something - seems like the Patriot sector 5 1600mhz 7-7-7--20 stuff is the best value and ample for overclocking headroom - am I likely to be limited by any of these kits overclocking-wise? I was under the impression that 1600mhz memory is more than enough headroom for overclocking. They'll be passively cooled in a zero-fan, open-sided case (see my sig) - anyone think there'll be heat issues?
Is it worth going for some of the more expensive kits - am I likely to see much difference, or are they just for people with money to burn?
or
or
or
Need to order soon!
