If you know your RAM serial number, there is a tool that can help you to find out what frequencies on what motherboard other users achieved. See here: http://rymem.vraith.com/
Just checked with my motherboard and it only supports 2666 MHz ram so what should i get? btw the mboard is ASUS PRIME X370
If you enter the timings manually. you should get higher speed ram to work. Anyway buying 3200 and running it at 2666 is no big deal initially. Any ram will run slower than the rated speed/
Trident Z, Teamgroup dark pro, most ram with single ranked samsung b IC should work.
My Tomahawk B350 is rocking Corsair CMK16GX4M2B3200C16 which is SK Hynix memory running smoothly at 3200Mhz.
Hmmm, so... everything confirms it's running at 3200 (e.g HW info, etc)? If so, what was needed to get it running ok? Much manual tweaking?
Proof here:
https://forums.overclockers.co.uk/posts/30695419/
No manual tweaking, set AXMP profile 2 and it run first time and been solid.
wasn't doubting your claim, just curious if it took much work![]()
