Yeah the pwm version can be controlled from your motherboard. You won't get migraine inducing levels of brightness, but I got a good amount of light from a single fan.Thanks i just had a look and the be quiet lightwings 120mm are £22 or £55 ish with a hub
Is there light output good and can they be controlled to drop the speed??
Didnt understand how these fans could be vs the ones i got now
the fans you have now are on the extreme budget side, most fans will be betterDidnt understand how these fans could be vs the ones i got now
So which fans outta em all that are silent do u reccomend?there a nice fan but for the cost they don't look as premium as others.
the D30 been 30mm also have very good air flow, and the lian li are a 28mm with aluminum hubs.
the 2 fins lock together for a seamless RGB affect.
if you going to pay £55 for a fan with a hub... you can get 3 lian li with a hub for £20 more, or 3 phanteks that dont need hub again for only £20 more
Thanks they do look niceThe hub is used if you havent got enough rgb headers on the motherboard. Also helps with cable management
Here is a build I did for a friend in 2023 using lightwings. This is their default colour
At night
And finally the colour theme he wanted.
only you can decide on priority. I only have 1 Bequiet in my system and when ran slow, it’s completely silent. You can adjust the brightness but I don’t like rgb to be too bright. I can only really comment on the sound as that’s my only priority.Thanks they do look nice
However the cheapish fans i have atm prob give off more light tbf
But they are not the quietest
lian li unifans
For sure, the ones with the LED screens also look pretty sweet and seems useful to have system info at a quick glancethis is what i have right now. i think the RGB on the D30 is better but the lian li do look very good and its very simple to control everything.
you can set the rad fans to follow CPU temp and the intake to follow GPU temp i do like this option.
