4 Oct 2011 at 22:05 #1 josh3190 josh3190 Associate Joined 15 Aug 2011 Posts 171 Location Southampton putting a 64gb intel m4 into an ASRock MOBO and wondering which sata port to put it into, sata3_0, sata3_1 or sata3_M1, sata3_M2 cheers guys! JT
4 Oct 2011 at 22:10 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 One of these: sata3_0, sata3_1. The others are the dire Marvell controller.
4 Oct 2011 at 22:10 #3 josh3190 josh3190 Associate OP Joined 15 Aug 2011 Posts 171 Location Southampton Cheers buddy! JT
4 Oct 2011 at 22:12 #4 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 You're welcome. Enjoy
4 Oct 2011 at 22:13 #5 josh3190 josh3190 Associate OP Joined 15 Aug 2011 Posts 171 Location Southampton Also when plugging in the system panel header pins, does the little arrow denote the positive pin? JT
4 Oct 2011 at 22:18 #6 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 Yes, it means positive. FYI I think it's a triangle.
