Which second monitor
11 Aug 2003
UK
Hi
I'd like a second montor to go with my Dell 24". Thinking of either a widescreen rotated vertically. Or a 4:3 ratio sitting the normal way. The question is, what size will give me the same screen height as the dell? Can it be done?
Thanks,
Philip
Caporegime
20 Jan 2005
Co Durham
Well a 21" 4:3 is a pretty close match. 12.62" compared to your 12.72" high screen - 2.5mm difference.
http://tvcalculator.com/index.html?7b268804a7e4c95ef5e474fab6946f9f
A 21.2" 4:3 screen would be an almost perfect match if such a screen exists - less than 0.5mm difference.
As far as ws rotated you will be looking at a 15" ws. If such a thing exists, rotated it will be the exact same height as your 24" screen.
http://tvcalculator.com/index.html?e0c6a289bda867903b0834832e3afa9c
Personally since a 15" screen rotated would only give you 8" of width so I'm not sure how much use you get, I would look for a 21-21.2" 4:3 screen. This will be far more practical and you'll get 16-17" of width.
Also the low res of the 15" screen would drive you up the wall IMO. The 20" 4:3 would be the same res height wise as well: 1200. So even if there was a slight difference in physical height, the res would be the same.
Just done a quick search and you can get quite a few 21.3" screens so that would be my choice
