Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Academic
Canon did change their mount and at the time it did alienate and upset a lot of their users, and since then in those 28 years they have released hundreds of lenses, many many of those are now into their 2nd and 3rd generations. I can't really think of many focal length where they are significantly fall short in such a way with a massive hole that Nikon has the advantage due to their old lenses designed back in 1955 or something that you can buy which are made on the old mount. In fact, I would hazard a guess that there are more AF lenses that Canon makes on the EF which Nikon do not and not the other way round. With regard to EF-S mount, that's not a replacement of the EF mount and EF-S cameras can still use EF lenses, same principle as new Nikon cameras can use old Nikon glass. One can ignore the EF-S lenses entirely and concentrate on the EF lenses.
Back in the real world.
And ask anyone, people will say Canon has more glass to choose from, they base that on the fact that there are more auto focus glass to choose from, all made post 1987. Nobody say Nikon has more glass to choose from and then add the caveat "if you include their old mount". Nobody, except DP. People do not go out of their way in general to seek out glass in the old mount to fill a hole in the focal length. They would rather get an auto focus lens that is perhaps does not have the desired aperture or a lens made by a 3rd party like Sigma to fill to gap rather than go the old mount route. People who seek out old glass like that tends to know the particular lens in question and would go out of their way to do that because they want to experiment with that particular glass, not as a solution for the focal length.
