which soundbar
2 Aug 2006
Liverpool
hi, I have the Samsung 43KS7500 and want to get a soundbar for it, I currently have Sky Q UHD and Panasonic UHD HDR blu-ray player connected to the tv but plan on adding an Xbox 1 X in the future, what soundbar should I get, budget £600-700
I've shortlisted 2, what should I get, it will be used for general tv, films, youtube and listening to music, here's the list
Samsung HWMS750 £439.00
Yamaha YSP2700 £649
In a straight comparison, I'd plump for the Yamaha. It is the more complete package since it includes the subwoofer. It has better connectivity too.
The ace up the Yamaha's sleeve is the direct/reflecting sound technology that means it can do surround without the cost and complexity of additional rear speakers. This means it can do what the Samsung does, which is to be a 3 channel sound bar, or you can switch it to full surround where it bounces rear surround off the walls in your home in a similar way to how ATMOS up-firing speakers work.
I have to say though that the surround facility isn't for everyone. It's dependent on the room layout. That said, it still has the edge over the Samsung even in 3 channel mode.
The Samsung would better suit people who value the gimmicks such as the wireless TV* connection and Amazon Alexa integration. The connectivity isn't as good, and I'm not convinced by Samsung's own in-house DSP effects. To match the sound capabilities of the Yamaha means adding the £180 rear speakers and the subwoofer at £400 or £600 depending whether you buy as a package or upgrade later.
The sub really is the star of the show. If you were considering the sound bar + sub package at £900 compared to the Yamaha at £649, then it would be a bit of a tougher call. Sonically, the sub makes a big difference to the sound, but it's still a hefty price tag.
FWIW, I think Samsung are benefiting tremendously from their ownership of US company Harmon Kardon which has a reputation for sound research. These newer Samsung sound bars are a result of the R&D work done by HK. They're a definite step up from Samsung's own Korean designs.
* Only applicable to specific compatible Samsung TVs
I have the Yamaha 2700 and it’s a great bit of kit. Had a few others before inc Sonos & sub and even a full Denon & Q acoustics setup but the 2700 sounds nicer to me. My room is pretty square so the surround works really well also the presence the bar produces is stunning. It has 4K and hdr pass through with 3 hdmi inputs.
Can you go anywhere and have a listen ?
listening in store is a bit awkward due to my wheelchair
Fair enough it’s a great sound bar and I’m sure you will be happy. I have had mine for a while now and it still impresses me when I use it. The way it projects sounds all over the room is amazing it creates such a wide sound.
I would consider buying from Richer Sounds as if you are not happy for any reason they are usually good with returns.
I had the yamaha 2500, is the 2700 better do you know
I would say so the reviews seem to say it’s considerably better but I have not heard the 2500 to compare myself.
Just remember the sub ideally needs to face the listening position for best results. You cannot really hide it away like separates as it does all the midrange work too. Having a nice square shaped room will also give better results.
