no bad points now that the firmware issues have been sorted. i can only recommend on my own experiences, so i say get the corsair as their customer service is second to none imo. i have heard bad things about ocz's service although others might be able to blow that out of the water?
i was looking at the force 3 before too but found out there are a new batch from sandisk the toggle nand which supposed to be better than asynchronous and synchronous nand! the 240gb supposed to be better than the 120gb too... but the drives are out of stock at the moment
The vertex 3 will definitely be faster than the force 3, but am not too sure about the force gt in relation to the vertex 3. But the vertex 3 is a fantastic drive overall so I'd just go for which one is cheaper between the two.
