5bjoshua said:Artic Silver 5 without a doubt! About 5*C
I second that5bjoshua said:Artic Silver 5 without a doubt! About 5*C
ernysmuntz said:You don't need Isopropyl to clean the chip.
Just use nail varnish remover, it does the same thing.
Some people will say that it leaves a residue, I would say "I've been using it for about 6 years from Athlon\AthlonXP\A64 dual core\A64 opetons\A64 single core chips no problems at all.
Does a super job I used it to remove the sticky pads that came with my crappy akasa 862 heatsink fan before i got a scythe infinity and thats doin 3.18ghz no problem![]()
Hades said:No, I wouldn't recommend nail varnish remover. It will leave a residue which will prevent the thermal paste from working as well as it could. The difference will only be very, very small. But I wouldn't recommend it unless there is nothing else to use.
